speaker burn-in.
0 Members and 1 Guest are viewing this topic. Read 1331 times.
IronForge
speaker burn-in.
« on: 3 Aug 2007, 07:46 pm »
Danny, I read your page on speaker burn in: http://www.gr-research.com/burnin.shtm
How loud should you be playing the speakers for a proper burn-in?  I would think a higher volume would give the suspension a little more of a workout.  Could a proper burn-in take place at a low or moderate volume?
Danny Richie
    • http://www.gr-research.com
Re: speaker burn-in.
« Reply #1 on: 4 Aug 2007, 04:11 am »
There is really two levels of burn in taking place. One is electrical, the other is mechanical. Mechanical change is the more easily documented (obviously). And yes, the harder you work it the quicker it will reached a settled compliance level, but it will eventually get there at low to moderate volumes as well.
