Technics 1200 anti-skating problem! Help!!!
0 Members and 1 Guest are viewing this topic. Read 1667 times.
murillo
« on: 2 Aug 2007, 09:31 pm »
Hello everybody,
I bought an used 1200 MKII from ebay and it came with a anti-skating problem.
When I put the cartridge weight at 0 grams (float test), - I´m using a Shure V15 IV - the arm goes in the outer direction (going to the right) even if the anti skating is at zero. I´m noticing huge amount of distortion when hearing the final tracks of each side (near the  end) on the left channel indicating that less anti-skating force is needed. How can I reset the anti-skating to less than zero?
Sorry my poor english...
Murillo
murillo
Re: Technics 1200 anti-skating problem! Help!!!
« Reply #1 on: 7 Aug 2007, 01:54 am »
I just solve the problem, removed the spring and viola!!!  Now it´s other sound, very clean. Thanks
