Dupli-Color UC103
0 Members and 1 Guest are viewing this topic. Read 1766 times.
TheChairGuy
Dupli-Color UC103
« on: 1 Aug 2007, 05:37 am »
http://www.caswellplating.com/vht/undercoatingk.html
Spray the underside of your aluminum platter with this stuff and you'll be a happier vinyl-phool  :guitar:  Under $10.00 buys a lot of bliss - and it's ready to roll 15 minutes after you use it.
Direct Drivers - you ain't done all you can for our deck if you haven't used it. Your motor is directly engaged to your oft-ringing aluminum platter - deaden it and enjoy your music so much more.
Belt Drivers, ymmv, but in general it should be quite beneficial for you.
Just make sure you prepare the surface by wiping grease and dirt off, and mask the spindle hole and outer platter to avoid sprayover.  You may use about 4oz total, so there is little possibility of you adding undue mass or knocking your platter out of balance if yo use careful spray strokes.  On balance, it's one fine tweek for under-$10.00  :D
