GLUE??
0 Members and 1 Guest are viewing this topic. Read 2174 times.
RawB8figure
GLUE??
« on: 30 Jul 2007, 11:39 pm »
which glue do you guys use with MDF. Would the glue also work for laminating a couple sheets together.
RAW
Re: GLUE??
« Reply #1 on: 31 Jul 2007, 12:51 am »
Yellow wood glue.
And yes it will work for lamination of MDF to MDF.
RawB8figure
Re: GLUE??
« Reply #2 on: 31 Jul 2007, 03:20 am »
I have some titebond will this work also. I was also wondering if I laminate a couple pieces together and paint it will the paint crack from creeping
RAW
Re: GLUE??
« Reply #3 on: 31 Jul 2007, 04:53 am »
Should not creep , yes you can use titebond
