Can someone get a tape measure out...
0 Members and 1 Guest are viewing this topic. Read 1298 times.
yooper
« on: 28 Jul 2007, 12:54 am »
and measure the distance from from the back feet to the front feet on a Mono Extreme?
I found a nice 5 shelf isolation rack, but the shelves are only 16.5" deep.  I know the chassis length is 18 inches but if all four feet will sit on the shelf, I don't mind a little chassis overhang.
Thanks in advance,
Mark
« Last Edit: 28 Jul 2007, 02:37 am by yooper »
Rob S.
Re: Can someone get a tape measure out...
« Reply #1 on: 28 Jul 2007, 03:29 am »
My feet on my mono extremes SE are 15 1/2 inches from back to front ( and that's the outer side of each )  You'll have overhang, but the four feet will be safely on a rack with 16.5 inch depth.
Rob S.
yooper
« Reply #2 on: 28 Jul 2007, 04:09 am »
Thanks a lot Rob, very much appreciated.  :thumb:
Mark
