41hz Amp4 - Telling MOSFETS apart, and measuring Inductance without a metre
0 Members and 1 Guest are viewing this topic. Read 2567 times.
Reverie
    • My Myspace
Hey all!
I've nearly finished a 41hz amp4 kit, but I've come across a pair of issues I could do with some advice on, and I can't seem to get the 41hz site to work for me.
If anyone can lend any advice, it would be greatly appreciated! :)
Firstly, how do you tell the difference between the N-channel and the P-channel Mosfets? They both appear to be in the same bag, and I can't tell the two apart  :oops:
Secondly, is there any way you can measure an inductance without an inductance meter? Can you apply a signal with a signal generator and then measure the resistance with an ohm-metre, then do some formula work?
Thanks to all who can help!
peter
ohenry
Hey all!
Firstly, how do you tell the difference between the N-channel and the P-channel Mosfets? They both appear to be in the same bag, and I can't tell the two apart  :oops:....
peter
Q4,5 and 6 use the part labeled "SA 1".
Good luck!
Reverie
    • My Myspace
Hey Henry!
Long time no speak.
Thanks for that! Should solve the first problem!  :)
I'll send you an email when it's all finished.  8)
Speedskater
  • Kevin
Use an AC Voltmeter (it doesn't even need to be accurate) a resistor in series with the inductor across the output of a small power amplifier. Output a 1 or 2 Volt sine wave. Adjust the frequency and resistor value until the voltage across the inductor is the same as the voltage across the resistor.
       xL
L = ______
      2 pi f
