SME series III
0 Members and 1 Guest are viewing this topic. Read 2846 times.
rustneversleeps
SME series III
« on: 25 Jul 2007, 05:59 pm »
I've found that I can learn more than just AVA in this forum, so I decided to give this one a try.
I've recently acquired a SME series III tonearm and don't have a turntable for it, most newer tables nowadays come with their own tonearms, so the manufacturers can set a "package price", that makes getting a turntable without arm not very cost effective.
Which turntable I should look for to mount this arm? I don't want to get a Thorens 125, since I've already have one. Years ago, Frank mentioned that AR and LINN were no good (unshielded motor), so I won't consider them.
Now about the SME III tonearm, I think I grabbed this one too fast without knowing a whole lot about it because of the good price, so what should I look out for about this arm? I've heard that setting it up is a real pain, is this true?
martyo
Re: SME series III
« Reply #1 on: 25 Jul 2007, 06:28 pm »
I had one in the late '70's and don't remember it being to difficult to set up, but maybe I set it up wrong. "mark funk" on this circle might be able to help you. (before you ask, it was mounted on a Kenwood KD-500 w/ a concrete resin base, direct-drive, and as Harry Pierson would say "totally unacceptable".) :nono:
WEEZ
Re: SME series III
« Reply #2 on: 25 Jul 2007, 06:38 pm »
There are plenty of 'tables that could be drilled to accept the SME....depends on your budget. As for shielded motors, that would affect the cartridge moreso than the arm....
WEEZ
martyo
Re: SME series III
« Reply #3 on: 24 Aug 2007, 10:37 pm »
Rusty, what became of your SME III project?
mark funk
Re: SME series III
« Reply #4 on: 24 Aug 2007, 11:36 pm »
I would hope he would dump that piece of ---- and get a good arm, I have one and it's sitting in my junk pile along with that Kenwood KD500 table! :smoke:
HAL
Re: SME series III
« Reply #5 on: 24 Aug 2007, 11:41 pm »
If you do not want the SME III arm, I will give it a good home!  :D
mark funk
Re: SME series III
« Reply #6 on: 25 Aug 2007, 02:36 am »
HAL, I PM you about the SME :smoke:
