Sun Audio SVC-500 Tube Preamp
0 Members and 1 Guest are viewing this topic. Read 5353 times.
MT POCKETS
« on: 25 Jul 2007, 08:39 am »
Just retubed and in excellent condition. $1400.00
All of the transformers (Power, Choke and Input/Output) are specially manufactured by Tamura Corp.
A hard-wired is mainly used for the circuit. In addition, Printed Circuit Board is used in a little part (amplification section) only.
This model has a design matching with SV-amplifiers except for SV-300BSM because of mostly same Width and Depth. (which can be used with SV-amplifier setting it on the top panel.)
Specifications for SVC-500 Tubes ECC82 x2, 6X4 x1
Circuit Design "Cathode Follower"
Line Inputs XLR (Balanced): x1 (CD1) (*1)
RCA (Unbalanced): x4 (CD2, TUNER, AUX1 and AUX2), also with REC IN x1
Input Impedance 100kohms (Unbalanced)
600ohms (Balanced)
Line Outputs XLR (Balanced): x1 (*2)
RCA (Unbalanced): x1, also with REC OUT x1
Output Impedance 10kohms (Unbalanced)
600ohms (Balanced)
Frequency Response 10-130kHz/-3dB (VR:MAX)
MAX Output 50V/1kHz
Gain 22dB/1kHz
Noise level less than 0.1 mV
Power Supply 100, 120 and 220-240 VAC can be accepted at 50/60Hz (must select one) (*3)
AC Connector Equipped built-in noise filter with detachable AC cord
Dimensions W360/H90/D300 mm
Weight 8.5 kg
*1 It is selectable at "CD1" position (left end) with the selector knob on the front panel.
*2 It can be chosen with the left (toggle) switch on the front panel.
*3 Now, we deliver this model with exchanging between two kind of power transformers like below in order to be used for all over the world.
« Last Edit: 25 Jul 2007, 09:27 am by MT POCKETS »
