What were the music selections from Friday?
0 Members and 1 Guest are viewing this topic. Read 1795 times.
Vapor Audio
  • Building Audio Bling since 2007
    • Vapor Audio
« on: 23 Jul 2007, 06:18 pm »
Hey guys, just wondering what were the albums we listened to Friday evening?  Also Chris, what's the contact info for that tube pre-amp guy here in St Louis?
Just an FYI, the OB2X's are ready for another listen.  On the woofer circuit there's a parallel 2ohm resistor that brings down the level a couple db in the crossover region.  I asked Danny how to add a bit of midbass energy to the design, he suggested removing that resistor.  I modeled it out and it looked good with the change, and I just finished removing it.  I also shortened the port by about 1/2" and reworked how I had the stuffing.  Now it does have a more balanced presentation, the last change will be getting some sturdy spiked bases made ... then it would be fun to compare to the Sentinels, for about 1/4 the price :)
bpape
    • Sensible Sound Solutions
Re: What were the music selections from Friday?
« Reply #1 on: 23 Jul 2007, 06:30 pm »
After the Illinois crew has the Sentinels, why don't you bring the OB's over to my place and we can compare them.  I have a controlled room and enough juice to make the Sentinels stand up and sing with no problems.
We listened to:
Lyle Lovett - Joshua Judges Ruth
The Winter Pills - Winter Pills
The new Gateway Reference Organ CD
Dire Strats - Love Over Gold
Casandra Wilson (don't remember the CD title though)
Help me out with the rest guys - old-timers is taking over...
Bryan
steve k
« Reply #2 on: 23 Jul 2007, 07:12 pm »
The CAssandra Wilson was "Belly of the Sun". You did better than me at remembering! :green:
steve
Vapor Audio
    • Vapor Audio
« Reply #3 on: 23 Jul 2007, 07:13 pm »
Sounds like a plan.  I should have them ready in 2-3 weeks, all I'm waiting on is my bro-in-law to make me some 1/2" steel bases for them, he works at a machine shop.  I figure that'd be the way to go, since they could use some heft at the bottom of the cabinet.
Thanks, Winter Pills was the one I couldn't remember.  There was also one other album that you'd just bought that day, I think the band was a one-word name ... hmmm.  I remember that I'd heard track 3 on 93.3.
bpape
« Reply #4 on: 24 Jul 2007, 01:46 am »
The band's name was Gomez.  The title is 'How We Operate'
Bryan
