Cornet 2 to Cornet 3 Upgrade Path?
0 Members and 1 Guest are viewing this topic. Read 2626 times.
WGH
« on: 21 Jul 2007, 05:37 pm »
Jim - The Cornet 3 sounds interesting:
Quote from: Hagtech WebLog July 20, 2007
I think it is the number one reason the TRUMPET sounded so good, not the fact that it was differential.  So imaging a single-ended CORNET style phono with TRUMPET style power supplies. Good power factor means choke input supplies, no diodes pulse charging caps, like every other design out there.  And I mean all of them.  Because I want to do the choke thing on the heaters too, not just B+.  Well, this leads to a lot of iron, a low of magnetic fields, and more cost.  But not that much more. Pretending I used the same chassis, I came up with all new designs for a phono and a monoblock.  The phono has 6.3Vdc heaters from balanced bipolar choked rectification.  Normally this ends up at +/-5Vdc with a pair of 6.3V windings, but I made it lossy in an LCRC topology.  Result is about 20mV ripple.  Then for B+, using the small power transformers (that fit under hood), I can barely squeeze out 210Vdc or 220Vdc.  That's way lower than what a CORNET requires.  Ok, how about using 12AY7 or 6072 tubes for the gain and EQ stage with CCS? I think noise will go down, linearity up, dynamics too.  Heck, I almost don't need the CCS, a 50k plate load might do the trick.  I like this tube.
Is there a possibility of an upgrade kit for us happy Cornet2 owners? A separate case for all the iron and chokes with an umbilical cord would be perfect. I would guess you already have a large Cornet2 client base that would be interested. As VPI, Linn, and many other manufacturers have found out - audiophiles love an upgrade path. A post card or email to past customers would generate interest, and a pre-order sale would cover development costs.
hagtech
Re: Cornet 2 to Cornet 3 Upgrade Path?
« Reply #1 on: 21 Jul 2007, 08:26 pm »
Whoa, that's thinking way ahead.  I'm just in the conceptual stage on this.  A blip of a brain fart.  A what-if?  I doubt very much that a C2 can be made into a C3 without some serious modification.  Basically, you'd be left with sockets on the board.  Most likely I will not even call it a C3.
jh
