Anyone use Walker High Definition Links?
0 Members and 1 Guest are viewing this topic. Read 1012 times.
mca
« on: 21 Jul 2007, 04:18 pm »
Just curious if anyone uses these or has tried them and what their thoughts were?
  • Speakers....What Speakers ?
Re: Anyone use Walker High Definition Links?
« Reply #1 on: 22 Jul 2007, 08:11 am »
Mike...
Did find a review on 6moons......amd tweekgeek sells them. Check and see if there's a demo period to check them out.... :thumb:
Stercom
« Reply #2 on: 22 Jul 2007, 08:27 am »
I use 2 pair on my Gallo Ref. 3.1 speakers. They expand the soundstage and make a clearer window on the music if you know what I mean. They also work the best in high resolution systems. If you try a pair make sure you install them correctly since reversing the polarity makes a noticeable difference.
