Comparing GR A/V-1 and AV123 x-ls
0 Members and 1 Guest are viewing this topic. Read 2982 times.
joeriz
« on: 21 Jul 2007, 03:09 pm »
Hi all,
I was wondering if someone could tell me the difference between the A/V-1 and the x-ls.  All things being equal, is it worth building the A/V-1 vs. just buying the x-ls and doing the Skiing Ninja upgrades?  From the little I've read, it seems like the latter gets you 'there' without having to build the cabinets.  And the cabinets on the x-ls look like they're quite well made.
(I guess the same might also be said of the A/V-3 vs. the x-mtm.)
Any thoughts would be apprectaed.
Joe
Danny Richie
Re: Comparing GR A/V-1 and AV123 x-ls
« Reply #1 on: 23 Jul 2007, 04:51 pm »
Both are great values but different.
The X-LS uses good quality parts but not the extreme high quality parts that come with the A/V-1 kit, especially if ordering the kit with a Sonicap upgrade.
The result of the difference in parts quality is a performance advantage for the A/V-1. Detail levels and resolution will be better in the A/V-1 and they will have a more clear overall sound.
The tweeters are made similar other than the face plate and dome material. They do sound slightly different but one is not a huge stand out over the other.
The woofers are also very similar and made by the same manufacturer. The X-LS uses a larger 6.5" woofer while the A/V-1 uses a smaller 5.25" woofer.
I'd have to give an edge to the A/V-1 in the upper ranges of the woofer as it is smaller, lighter and more agile. But it gives up some fullness and body to the larger X-LS woofer.
With the near 3khz crossover of the A/V-1 being a series crossover there is really good driver integration that would not be possible with the larger woofer if crossed that high, but the larger woofer in the X-LS is not having to play as high. It is crossed in the 2kHz range so not much of an advantage to the A/V-1 there.
If the X-LS were upgraded (a la Ninja Master crossovers) to the same high quality parts the differences between the two would be subtle with one advantage still going to the X-LS. That would be the bigger and fuller sound from the larger woofer.
joeriz
« Reply #2 on: 23 Jul 2007, 06:31 pm »
Thanks, Danny.  Sounds like the x-ls with the Ninja mods is the way to go if you don't want or have time to build the cabinets.
A few more questions if you don't mind...
The x-sls also looks intriguing.  Are there Ninja upgrades available for that as well?  How does the x-sls compare to the x-ls?  The same with a bit more bass?
Also, how do the Rockets compare with the x series?
Thanks again,
Joe
joeriz
« Reply #3 on: 12 Aug 2007, 12:36 pm »
bump
(Danny - sorry if my question regarding the Rockets was out of line...it was not meant to be but it occurred to me later that it may have been a dumb thing to ask since you work with the AV123 folks.)
Could you comment on the x-sls per my question above?
Joe
Danny Richie
« Reply #4 on: 12 Aug 2007, 12:49 pm »
Sorry about forgetting about your questions.
Sure. They use the same network as the X-LS.
They are the same speaker, but the X-sls is an optimal ported enclosure and it allows for more low end extension.
Also good, but different.
jrebman
« Reply #5 on: 2 Sep 2007, 10:56 pm »
Would it be possible to use the 165 xbl driver in the X-LS?
-- Jim
Danny Richie
« Reply #6 on: 3 Sep 2007, 02:09 am »
Not with the same crossover.
If you want a step up from the standard X-LS there will be a new version using a really high quality tweeter plus upgraded caps (Sonicaps) all for only $299. a pair. All will be available through AV123.
