Pace-Car reclocker for Squeezebox3 up on the website
0 Members and 1 Guest are viewing this topic. Read 1917 times.
audioengr
« Last Edit: 29 Aug 2007, 05:43 pm by audioengr »
drrd
Re: Pace-Car reclocker for Squeezebox3 up on the website
« Reply #1 on: 22 Jul 2007, 08:22 pm »
hi steve, just a few queries about the latest info on the pace car.
hadnt realised there was a possibility of using an external clock. can this come in via wordclock? would this allow the possibility of a wider choice of clock rates if the external clock can generate them? does the quality of the onboard clock become irrelavent if using an external one?
will the pace car be able to handle 48k sample rate? this is going to be important for dvd playback, i dont know of a software dvd player that will upsample to 96k. also wondered about the reason for having 44.1 sample rate limited to 16 bit?
thanks
« Last Edit: 23 Jul 2007, 08:54 pm by drrd »
audioengr
« Reply #2 on: 24 Jul 2007, 04:02 am »
Yes, but only as a master clock, not a word clock input, and it must be 11.2896 or multiples or 24.756 or multiples.
The Pace-Car version 3 can output master clock, bit clock or word clock for 16/44.1 or 24/96.  Input is only master clock.
In the transport or networked converter, the internal clock is replaced with the Pace-Car clock.  For Transports, the word clock will lock the internal master clock.  The quality of the transport clock is not important.
If you are inputting a clock, the there is no need for an internal clock in the Pace-Car.
No. Mainly because the converters and DAC's do not support AC3 anyway.
I had not planned on provinding the frequencies required for DVD players.  These are usually 27MHz master clock and there is a frequency synthesizer that creates all of the other frequencies.  DVD players do not have a clock that can lock-on to a word-clock.
I could make a customized version to do 24/48 though.
Steve N.
