Anyone tried using a 5U4 instead of the 5AR4 for the SE9
0 Members and 1 Guest are viewing this topic. Read 2780 times.
ninja2586
I've heard some really good things about the 5u4 in the ST70 as a replacement for the 5AR4.  But that tube draws about an amp more from the power transformer.
I was wondering if the SE9's power transformer can handle the extra load from the 5U4.  Anyone tried this sub??
albee
« Reply #1 on: 26 Aug 2003, 02:42 am »
Don't be brave enough to be the first to try it!
Those two tubes are usually aren't interchangeable in any rig.  See if Mike can find out for you first.
ninja2586
« Reply #2 on: 1 Sep 2003, 04:52 pm »
Quote from: albee
Yeah, that's my first thought.  I emailed Mike Barnes and he referred me to Yuths in his office.  Yuth finally got hold of the manufacturer and told me that we can use the 5U4 w/o modifications.   This is good as I'm told that the 5U4 can produce better sound than the 5AR4/GZ34 can ... at least in this one application of a modified ST70.
Besides, the 5U4 NOS seems to be MUCH cheaper than the 5AR4/GZ34 tubes as well.  I've got one on order and will give it a try.  Anyone else??
JohnR
« Reply #3 on: 1 Sep 2003, 11:31 pm »
5U4 is directly heated and the amp will start up faster than a 5AR4.
FWIW....
ninja2586
« Reply #4 on: 1 Sep 2003, 11:41 pm »
Quote from: JohnR
FWIW....
If I were to use it, what's your recommendation as for the startup issue?? Wait a couple of extra seconds before turning up the volume??
JohnR
« Reply #5 on: 1 Sep 2003, 11:58 pm »
Don't really have a recommendation...
yeldarb
5U4 Rectifier in SE9
« Reply #6 on: 14 Apr 2005, 02:53 pm »
ok, those of you that have tried this tube instead of the standard, what were the results?
AudiophileBob
« Reply #7 on: 16 Apr 2005, 02:54 am »
The 5U4 uses nearly 1.5 amps more heater current.
This will result in more watts of extra heat and minimal sonic difference.
IMHO, I wouldn't stress my filament transformer for the doubtful gain.
The rectifier's output is filtered before it is used anyhow.
crossroadazn
« Reply #8 on: 20 May 2005, 04:44 pm »
:nono:  I wouldnot put 5U4 in ST-70 because of higher curent and heat it will shorten the life of other tubes. I got this problem in one of my ST-70s.
