For Sale - Kramer 466 Digital Selector/Format Converter/Router
0 Members and 1 Guest are viewing this topic. Read 1002 times.
PatrickKan
For sale of my Kramer 466 Digital 4x1 selector and Format Convertor for US$320. 98% new included original packaging, power cable and manual.
The 466 is a high performance transcoder for digital audio signals. It converts one of 4 digital audio formats or 1 twisted pair input to 4 digital audio formats and 2 twisted pair outputs simultaneously.
Features:
Inputs - 1 AES/EBU (110 Ohm), 1 AES-ID3 (75 Ohms), consumer S/PDIF (75 Ohm), Optical Toslink, and 1 CAT 5
Outputs - 1 AES/EBU (110 Ohm), 1 AES-ID3 (75 Ohms), 1 consumer S/PDIF (75 Ohm), 1 Optical Toslink, and 2 CAT 5 simultaneously
Sampling Rate Conversion - up to 192KHz at 24 bits
System Bit Selection - Professional or consumer (selectable)
System Range (Twisted Pair) - Up to 100 meters (300’)
Cable (Twisted Pair) - UTP (unshielded twisted pair) such as CAT 5
Compact Size - Part of the Kramer TOOLS" family of compact, high quality and cost effective solutions
Specifications:
INPUTS: 1 digital audio AES-ID3 on a BNC connector, 1 S/PDIF digital audio on an RCA connector, 1 Toslink ® optical, 1 digital audio AES/EBU on a detachable terminal block, 1 twisted pair on a detachable terminal block
OUTPUTS: 1 digital audio AES-ID3 on a BNC connector, 1 S/PDIF digital audio on an RCA connector, 1 Toslink ® optical, 1 digital audio AES/EBU on a detachable terminal block, 2 twisted pairs on detachable terminal blocks
SAMPLING: 32, 44.1, 48, 96, 192 kHz sampling frequencies
STANDARDS: IEC 60958, S/PDIF, EIAJ CP1201 and AES3 interface standards, as well as multi-channel standards
CONTROL: Input select, local twisted-pair selector, system bit selector
DIMENSIONS: 12 cm x 7.5 cm x 2.5 cm (4.7" x 2.95" x 0.98", W, D, H)
POWER SOURCE: 12 VDC, 60 mA
Additional information can be found at http://www.kramerelectronics.com/indexes/item.asp?name=466
Please email me [email protected].
Thanks for looking at my item.
Patrick
