is a simple dipole possible?
0 Members and 1 Guest are viewing this topic. Read 2222 times.
kyrill
« on: 17 Jul 2007, 05:55 pm »
hi
Is a simple dipole possible?
a very basic question , i know.
if i use a woofer box, standard design for 100hz and lower but want my Focal Audiom 7m midrange to take over from 100 hz in dipole fashion,
what is the formula for the baffle dimensions?  halve wavelength from side to side?
more or less this question is answered now by the figure in my next post
« Last Edit: 19 Jul 2007, 10:47 am by kyrill »
kyrill
hi
I found this image at http://melhuish.org/audio/baffle.html from Sound Practices
so i hope that my "story" of halve wavelengths is wrong and this figure is right?
so how is the formula?
el`Ol
Quarter-wavelength = baffle diameter would fit. But I can`t tell you why.
By the way: Here would be a nice special offer for a W-dipole sub:
http://oaudio.de/product_info.php?info=p162_CS-322-S.html&XTCsid=aimjseqbi7ehu2il84a6euq1g2
kyrill
thx el`ol
Back to my "simple dipole" question
will it sound "awful" if  only the midrange (100hz-2khz) is a dipole?
I thought dipoles would be simple to build but the more i read about it the more complex it is.
« Last Edit: 19 Jul 2007, 10:57 am by kyrill »
scorpion
Re: is a simple dipole possible?
« Reply #4 on: 19 Jul 2007, 11:45 am »
kyrill,
It will sound gorgeous. Look at the designs by GR-Research and Nomad Audio here in AudioCircle.
I have done a quick sketch proposal for a baffle in the Edge:
It is hard to see dimensions: 45 cm wide and 45/55 cm high, element center at 30/35 cm.
This will fit your bill down to 150-200 Hz without need for boosting the Focal.
/Erling
mcgsxr
« Reply #5 on: 19 Jul 2007, 02:35 pm »
Having built a number of open baffle speakers to date, I would say this about complexity - you can make it as complicated as you like, as you seek to optimize the design.
But for simplicity, cut a board, cut a hole, and listen.
Then play with wings, or extensions of cardboard with duct tape, and listen.
Then cut a baffle that matches what you like the sound of.  Period.
Works for me, anyway!
kyrill
« Reply #6 on: 20 Jul 2007, 09:06 am »
thx ppl
i will post in due time my findings
