Bugle, Bugle PSU, and Piccolo One box solution.
0 Members and 1 Guest are viewing this topic. Read 1545 times.
amandarae
« on: 16 Jul 2007, 09:39 pm »
Hello Jim and fellow Hagerman product enthusiast (I do not think Hagermaniacs is an appropriate term :D),
Do you see any problem making a one box solution for the units mentioned above?  I will have it on 12" x 8" x 3" chassis with the PSU, then the Piccolo, and the Bugle phono in that order.  I will have provisions so that I can separate the connections between the Piccolo and the Bugle Phono respectively if necessary but they have to share the PSU.
Jim, do you think a shield is necessary to separate the boards (compartment) especially the Bugle phono (thus my order recently!)?
regards and thanks in advance to those who will respond.
Abe
hagtech
Re: Bugle, Bugle PSU, and Piccolo One box solution.
« Reply #1 on: 17 Jul 2007, 04:21 am »
Yes, I changed the PICCOLO design to make it same size to fit to BUGLE.  So they all stack.  The connectors are not lined up, but wire is wire.  The key is to put a little distance between the power supply and the other boards.  Two inch standoffs should be enough.
jh
amandarae
« Reply #2 on: 17 Jul 2007, 06:04 am »
Thanks Jim!  I will keep it in mind that a 2" distance from the PSU is necessary.  I'll post when its finish.
Abe
