A freeware (and unique) RTA now available
0 Members and 1 Guest are viewing this topic. Read 5415 times.
bwaslo
    • Liberty Instruments
« on: 14 Jul 2007, 06:30 pm »
Just wanted to point this out to anyone who may need an easy to use and fast tool for arranging and adjusting speakers in rooms.  Freeware, no strings attached, and it works.
SynRTA is an RTA-like analyzer that uses continuous noise-like sound (played from a CD), but which doesn't need to "settle" when you measure -- each update of the graph is complete and easily and quickly repeated.
Anyway, it's freeware, and there is more about it at
http://www.audiocircle.com/index.php?topic=43121.0,
and at
http://libinst.com/SynRTA.htm (where you can download it from).
Vinyl-Addict
    • Groovetracer - Products for Rega turntables.
Re: A freeware (and unique) RTA now available
« Reply #1 on: 14 Jul 2007, 09:18 pm »
and at
Does your software run test tones for microphone calibration?
bwaslo
« Reply #2 on: 14 Jul 2007, 10:16 pm »
No, sorry. The mic calibration has to come from somewhere else.
You could, I guess, use it to calibrate the flatness of another mic, if you have another flat mic to compare with.
But it can't calibrate sensitivity.  It doesn't know sensitivity, only flatness.
Vapor Audio
  • Building Audio Bling since 2007
    • Vapor Audio
« Reply #3 on: 14 Jul 2007, 10:48 pm »
Sweet, a new piece of measurement software to play with ... thanks for making it freeware!
