SP2 setup
0 Members and 1 Guest are viewing this topic. Read 1095 times.
kas
SP2 setup
« on: 13 Jul 2007, 01:42 am »
I just received my SP2 and would like to set it up for two channels only. Are there any special settings that I have to worry about besides the front (L & R) speaker configuration, and crossover frequency?
thanks,
kas
Burke
Re: SP2 setup
« Reply #1 on: 13 Jul 2007, 02:34 am »
You've got a great pre/pro there. Be sure to select "Stereo" rather than "Surr" (surround). This may seem like a flippant remark, but it really does make a difference in the sound stage, imaging, etcetera, even with only two speakers connected.
By speaker "configuration", in addition to distance settings and "large" or "small", etcetera, I assume you are including channel balance, which needs to be done with either a calibration disk such as AVIA, or the built-in pink noise test tones (which take at least 30 seconds to engage; not just pushing the "Test" button, but holding it down for about half a minute) in either case, using a sound pressure level meter. Of course, this is also important to achieve a realistic sound stage and correct placement of voices and instruments.
Enjoy!
Burke
kas
Re: SP2 setup
« Reply #2 on: 13 Jul 2007, 04:05 am »
Burke,
Thanks for your response. I have to get me a SPL.
kas
