Speaker Spikes
0 Members and 1 Guest are viewing this topic. Read 1305 times.
Antman27
Speaker Spikes
« on: 7 Jul 2007, 11:11 pm »
Hello all -I may try to get my subs off the floor and up on spikes
The floor is a concreet slab with carpet
The Screws on the feet are 1/4-20 thread type
can anyone suggest any spiles with this thread and if they think this would be better than the sub just sitting on the floor
« Last Edit: 8 Jul 2007, 02:38 am by Antman27 »
macrojack
Re: Speaker Spikes
« Reply #1 on: 8 Jul 2007, 02:21 am »
I'm lost. Is this an ad?
Antman27
Re: Speaker Spikes
« Reply #2 on: 8 Jul 2007, 02:39 am »
OK Removed all the stuff from SVS website
I was just posting what was on the subs now
some young guy
Re: Speaker Spikes
« Reply #3 on: 8 Jul 2007, 03:37 am »
i just started using audio points under my speaker plinths and i also have a carpeted cement slab underneath. i've been extremely happy with the results.
http://www.starsoundtechnologies.com/15apthreaded.HTML
jeffreybehr
Re: Speaker Spikes
« Reply #4 on: 8 Jul 2007, 07:05 am »
Try Michael Percy Audio.  http://www.percyaudio.com/Catalog.pdf , bottom of p. 18.  $5 per 4 spikes.  Here's a pic of the larger ones.
OTL
Tweaker
Re: Speaker Spikes
« Reply #6 on: 8 Jul 2007, 07:02 pm »
Oregondv.com has a nice selection of brass speakers spikes with the thread size you need:
http://www.oregondv.com/spikes.htm
The sound should really benefit from the sub being mass coupled to the floor. Expect to hear better defined and focused bass.
I just now ordered some of the 2.15" spikes for my Hsu sub.
« Last Edit: 8 Jul 2007, 07:26 pm by Tweaker »
dnd
Re: Speaker Spikes
« Reply #7 on: 11 Jul 2007, 10:46 pm »
I put my two subs up on audiopoints [1/4-20 thread for what that's worth] and the improvement was not only immediately easily audible, but also dramatically measureable.  FWIW, my subs weight more than 100 lbs each, and prior to the spikes, the whole cabinet would shake/move on the carpeted floor.  Not so anymore which is likely why there was such a huge improvement.
