Wil non ipods synch with itunes?
0 Members and 1 Guest are viewing this topic. Read 662 times.
Doublej
« on: 4 Jul 2007, 04:19 pm »
Do I have to buy and ipod to synch with itunes or are their non Apple MP3 players that will sync as well.
itunes is running on a PC.
Watson
Re: Wil non ipods synch with itunes?
« Reply #1 on: 4 Jul 2007, 04:33 pm »
There are a few non-iPod players listed in the iTunes help file, most of them old models.  If it's listed there, it will work.  Otherwise the answer is no.
There is a piece of software called BadApple that lets you sync iTunes with any digital audio player that mounts with a drive letter, but it only supports MP3 format files and hasn't been updated in two years.  You should verify that it works for you before buying a player:  http://www.badfruit.com/index.html  Also, the trend in recent years is for players not to support drag and drop but instead require transferring files via a music transfer protocol.  Those players don't work with BadFruit either.
