SP2 Firmware
0 Members and 1 Guest are viewing this topic. Read 8183 times.
onthefly
SP2 Firmware
« on: 2 Jul 2007, 04:15 pm »
I have downloaded the new firmware for my SP2 & to be honest I haven't a clue what to do with it.  Is there not a simpler method for upgrading firmware?
What does the new firmware offer? :scratch:
  • The Demo is Everything!
    • http://www.bryston.com
Re: SP2 Firmware
« Reply #1 on: 2 Jul 2007, 04:24 pm »
Hi,
The new softwear just prevents the SP2 from accepting a command before it is fully booted up- helps in installations where there are multiple commands being given to many different components at once.
james
onthefly
Re: SP2 Firmware
« Reply #2 on: 2 Jul 2007, 05:38 pm »
Mmm, looks like I am going to need a laptop and a lot of patience.
Can someone tell me what a 'Hyper terminal session' is or will it become apparent once I am connected via a laptop and my SP2 is in BOOTLOADER mode. :duh:
brucek
Re: SP2 Firmware
« Reply #3 on: 2 Jul 2007, 11:53 pm »
The zip file you downloaded contains the .s19 firmware file, plus a word .doc file that explains how to load the fimware using the standard hyper terminal program in Windows.
The downloaded zip file also contains the terminal setup program in the zip file. After you extract the three files in the downloaded zip file, just double click the hyper terminal .ht file contained in the zip and it sets it all up for you. Then read and follow the instructions in the .doc
Pretty simple stuff...
brucek
onthefly
Re: SP2 Firmware
« Reply #4 on: 4 Jul 2007, 11:21 am »
You're right, a simple process.  Thanks for your help.
However, when I switch on now the display says 'searching for SPV, SPV not found'.  It did not do that before.  Any ideas?
Re: SP2 Firmware
« Reply #5 on: 4 Jul 2007, 11:28 am »
The new software searches for the Bryston SPV1 video switcher - if not found it moves on.
james
onthefly
Re: SP2 Firmware
« Reply #6 on: 4 Jul 2007, 11:33 am »
JT
Thanks for the prompt response.  I thought for a moment I had created a problem. :thumb:
alpsy
Re: SP2 Firmware
« Reply #7 on: 13 Aug 2007, 05:56 am »
hi all,
can someone please direct me to the latest firmware file for the sp2.
thanks,
julie
onthefly
Re: SP2 Firmware
« Reply #8 on: 13 Aug 2007, 08:13 am »
It looks as though it has been removed from the Bryston website :scratch:
http://www.bryston.ca/BrystonSite05/BrystonDocs.html#preamp
Re: SP2 Firmware
« Reply #9 on: 13 Aug 2007, 10:27 am »
Hi All,
Yes the firmware is only available now directly from Bryston.
We need the serial number of the unit and an email address.
james
brucek
Re: SP2 Firmware
« Reply #10 on: 13 Aug 2007, 12:33 pm »
So, will Bryston post a memo on the site when a new version is available, or perhaps note the date of the latest firmware?
Would this indicate that there will be different versions depending on the serial?
brucek
Re: SP2 Firmware
« Reply #11 on: 13 Aug 2007, 12:50 pm »
Hi Bruce,
More and more of our products are software driven (BCD-1, BP16, B100, SP2, new outboard DAC etc.) The great thing about the software driven products is that you can add features etc. as things move along.
We will post an noncements when there are new versions available and based on serial numbers send the appropriate update to the dealer or customer. I like your idea of posting the latest software date of each product.
james
alpsy
Re: SP2 Firmware
« Reply #12 on: 13 Dec 2007, 10:42 am »
How do I check the version of firmware I have on my SP2? When it boots up it says 4 Aug 2006 which I assume is its build date? It then goes on say version xxxxxxxx406 or something like that :)
im assuming its not the latest version given its over a year old so would also like to know where to find latest version :)
thanks all
julie
Re: SP2 Firmware
« Reply #13 on: 13 Dec 2007, 12:31 pm »
thanks all
julie
Hi Julie,
The Aug 4 date is the software.
There is a newer version - send me an email and I will forward the new software.
Also need the serial number of the unit and where purchased.
james
redsierra
Re: SP2 Firmware
« Reply #14 on: 16 Jan 2008, 12:29 am »
Hello James.
What IS the new firmware version?
Dwight
brucek
Re: SP2 Firmware
« Reply #15 on: 16 Jan 2008, 02:41 pm »
Yeah, I sure wish there was an entry on the Bryston website where we could check what the latest version was.
Is it a secret?
I guess I can understand why Bryston doesn't provide convenient download of the firmware as it use to, but I can't see any reason to not at least let us view what the latest version is.
brucek
Re: SP2 Firmware
« Reply #16 on: 16 Jan 2008, 08:23 pm »
Is it a secret?
brucek
The latest version of sotware in the SP2 is Aug 17th 2007
We have a BETA version of the software dated Oct 23 2007 which is not being used in production at this point.
The Beta version has a small change in the speed at which the volume control ramps up. Not enough of a difference to issue new software.
james
flom
Re: SP2 Firmware
« Reply #17 on: 12 Apr 2008, 11:11 am »
Hello,
I sent an email to James : I would like to upgrade my sp2 firmware. It is the original one : August 2006 27th
My SN is 263 and my retailer is JBKAUDIO (France). Could you please sent me the last SP2 Firmware & procedure?
Furtheremore, my amp makes a "ploc" when i switch from mutichannel (dvd) to bypass (cd) and also when i put off the bryston (trigger with amplifier on) from a multichannel position. No problem if i switch off the bryston from a pure analog (bypass cd) position
Could you help please ?
Thanks in advance for your returns
Cheers
Re: SP2 Firmware
« Reply #18 on: 12 Apr 2008, 11:26 am »
Hi flom,
I will forward this to Mike Pickett at Bryston for the software.
I am not sure what the 'ploc' is - it sounds like a grounding issuebut I will check with Mike.
You should always turn off your amp first when shutting down and turn your amp on last when starting up.
james
flom
Re: SP2 Firmware
« Reply #19 on: 12 Apr 2008, 11:44 am »
Hi flom,
james
Hi James,
the "ploc" is a returning sound from my amp to the loudspeaker indeed. Before the sp2, I had a sp1.7 and the configuration was exactly the same : my amp is still commanded by the preamp trigger.
Either in multichannel & analog positions, when i switch the bryston preampS off, the trigger (with its embedded tempo) trigger the amp off and then the preampS commute to off. Between the two states, there is signal (ploc) sent to loudspeakers, only when the SP2 preamp was in multichannel before shutting down.
