12-inch or 15-inch 96db or higher bass driver for OB use, augment B200s
0 Members and 1 Guest are viewing this topic. Read 2472 times.
Luigi
  • Busa doing the business
Anyone have any recommendations for the above?
I would like to augment the bottom end of the Visatons B200s.
But I don't want to do any padding to meet low-sensitivity low-end drivers. So woofers like Augies are out.
Anything else spring to mind? I ask because I saw a set of 97dB TAD drivers in the weekend but noted their Qts was lowish at 0.3. And their owner was reluctant to sell as he'd already spent squillions on them.
TIA for any suggestions.
PS Dont want to spend the earth on these, but don't mind a bit of lash either.
Russell Dawkins
would these do?
$170 21", 100dB, fs 31 Hz, QTS .98, cast frame xmax .75", no response curve, though.
http://www.shredmuzic.com/product_p/813-008.htm
Selenium woofers (made in Brazil) are supposed to be very good sounding and have a well-controlled HF roll-off with no high Q peaks or other nasty surprises so simple crossovers work:
http://www.partsexpress.com/webpage.cfm?&DID=7&WebPage_ID=112#woofers
el`Ol
