Headphones with volume control
0 Members and 1 Guest are viewing this topic. Read 1959 times.
jrokke
« on: 1 Jul 2007, 02:30 pm »
I was wondering if there is any quality headphones (no earbuds) with volume controls on them. I am running an imod (fixed output) for 2 channel use and would be interested in trying out some quality headphones with it. I would like to keep it simple (no headphone amp) since i don't know how often I would use the set up. Budget is $100, an ideas?
BradJudy
Re: Headphones with volume control
« Reply #1 on: 1 Jul 2007, 03:21 pm »
Do you have an existing pair of headphones you like?  If so, then just add something like a Shure in-line volume control (http://www.headphone.com/products/cables-and-adaptors/cables-by-others/shure-pa235-level-attenuator.php).  I use one with my UM1's since they are a bit too sensitive.
In the end, you'll end up with the best sound combining something like this with a headphone you like as very few nice headphones have a volume control.
Grado SR-80's would be a good option to try with the Shure volume control.
jrokke
« Reply #2 on: 2 Jul 2007, 05:44 pm »
Thanks brad. I will pick one of these up and then maybe some grado 60s or 80s. I think that would be a good entry into headphones. :thumb:
