nad s500 clock speed
0 Members and 1 Guest are viewing this topic. Read 1652 times.
drmike
« on: 29 Jun 2007, 11:20 pm »
hello, anyone know the clock speed of this cdp?
thanks,
drmike
art
    • Analog Research-Technology
Re: nad s500 clock speed
« Reply #1 on: 9 Jul 2007, 06:02 pm »
It is either going to be 11.2896 MHz or 16.9344 MHz. Philips-based units are the first, J. A. Pan, Inc. versions use the latter. There is an outside chance some units run at twice the normal frequency. My guess is it is Philips based. The logos on the chips should give you a clue.
Besides, you should be able to see the crystal, and see the frequency on it. There will be other crystals for the micro, so that may confuse some.
Pat
drmike
« Reply #2 on: 9 Jul 2007, 10:58 pm »
thanks pat.
drmike
Reference Audio Mods
    • http://www.referenceaudiomods.com
« Reply #3 on: 21 Jul 2007, 11:39 pm »
Hi,
Actually (depending on which model you have, there is the older version and the newer version), the clock speed is either 8.4672mhz or 11.2896. The older models used the 8mhz and the newer models use the 11mhz clocks. Hope this helps!
