looking for some phones for work
0 Members and 1 Guest are viewing this topic. Read 2008 times.
sts9fan
« on: 28 Jun 2007, 03:38 pm »
Hi
I am looking for some nice headphones for work.  I don't want to spend over $150 but that is really my only sticking point.  That and they should be able to run right off my computer or one of those TotalBit Head like units
R_burke
Re: looking for some phones for work
« Reply #1 on: 28 Jun 2007, 05:16 pm »
Grado's are low impedance and will run off of a computer, but they are open and will leak sound, I'm not familiar with closed phones that are in your price range.
Check out the reviews of various phones at:
http://www.headphonereviews.org/wizard.php
It's a decision tree to help you pick phones
ctviggen
« Reply #2 on: 28 Jun 2007, 05:44 pm »
I use Grado SR-60s at work.  At a level I typically listen to them, I can take them off my head, lay them about a foot away, and can hear nothing.  Absolutely nothing.  They make leak if you crank them, but I like my hearing.
acd483
    • www.anthonydumville.com
« Reply #3 on: 25 Jul 2007, 09:55 pm »
I highly recommend Grado SR-80s. I've owned mine for 5-6 years. For work, they're perfect...nobody will think to take them, and only you know how great they sound.
SET Man
« Reply #4 on: 26 Jul 2007, 12:23 am »
Hey!
  Yup! like others above me... here is another vote for Grado. :D
  Personally I've been using my SR60 since 1996.... 11 years now!!! :o
  If you are looking for a open-air type headphone that could be plug into any thing than Grado will do. I use it with anything from protable CDP, laptop computer to the 3wpc EL84 SE amp in my Akai M8 R2R tape deck. :D
Take care,
Buddy :thumb:
macrojack
« Reply #5 on: 28 Jul 2007, 12:54 pm »
I'm a Grado dealer. PM me for AudioCircle price.
