0 Members and 1 Guest are viewing this topic. Read 6641 times.
On the rare off chance if anybody is looking to move on their Altmann Dac please PM me. jaspal
Quote from: jaspal kallar on 27 Jun 2007, 04:55 pmOn the rare off chance if anybody is looking to move on their Altmann Dac please PM me. jaspalHiI've decided I don't want one for now. Thanks. jaspal
Quote from: jaspal kallar on 16 Aug 2007, 02:34 pmQuote from: jaspal kallar on 27 Jun 2007, 04:55 pmOn the rare off chance if anybody is looking to move on their Altmann Dac please PM me. jaspalHiI've decided I don't want one for now. Thanks. jaspalnot sure yet about the amp?
Ok I'm looking for one again. On the rare off chance if anybody is looking to move on their Altmann Dac please PM me. Thanks jaspal
Quote from: jaspal kallar on 17 Sep 2007, 08:20 pmOk I'm looking for one again. On the rare off chance if anybody is looking to move on their Altmann Dac please PM me. Thanks jaspalJaspal,I think you just order directly from Altmann Micro Machines. I was waiting for long to get one and guess the last used one was sold in a day. I do not know and have not listened to Attraction DAC but it seems most of the Attraction DAC owners are very satisfied to keep it for long time.
Jaspal,Have you tried to modify your BYOB amp by replacing the two Wima little red-orange cube coupling caps (near the volume control) with a pair of better quality metallized polypropylene caps. To my ears the BYOB amp will sound open up more (it was sounding so congested to me) and better separation.Congratulation that you finally get an Altmann Attraction DAC.
how's the BYOB DAC and Amp sounding now that you've had it a few weeks?
Quotehow's the BYOB DAC and Amp sounding now that you've had it a few weeks?Jaspal,Attraction DAC sounds very nice the way I expected but the amp was sounding so congested and little dry when I crank up the volume. That is why I have tried to modify with better quality coupling caps (well they cost only $20 each) with high value of mF(10mF) and bypass with PIO caps for smoothness. Tan
I'm really curious about one thing. You have the Altmann Dac and presume the hi-gain version of the BYOB amp and your speakers that are quite high sensitivity? If so can you turn the volume pot much before it gets too loud?
Jaspal,This is my concern too when turning up the volume pot to 10 o'clock which is the position I can stand with my high sensitivity speakers but if I just turn it up little bit more it would be too loud for my ears even though I already connected Promitheus TVC in between. I think Charles designed the BYOB amp for the "hard to drive" speakers too but I do not understand why most of BYOB amp owners (including me) have their suggestion for high senstivity speakers. That is why my next move is to replace the stock volume pot with a stereo stepped attenuators 100K that I have in hand.How did the other BYOB amp owner replace the stock PS caps with BG 10,000mF/63V? Do you have any pics or do you know what caps have to be replaced (I can see the two silver caps and two small caps in between)?Tan
QuoteI'm really curious about one thing. You have the Altmann Dac and presume the hi-gain version of the BYOB amp and your speakers that are quite high sensitivity? If so can you turn the volume pot much before it gets too loud? Jaspal,This is my concern too when turning up the volume pot to 10 o'clock which is the position I can stand with my high sensitivity speakers but if I just turn it up little bit more it would be too loud for my ears even though I already connected Promitheus TVC in between. I think Charles designed the BYOB amp for the "hard to drive" speakers too but I do not understand why most of BYOB amp owners (including me) have their suggestion for high senstivity speakers. That is why my next move is to replace the stock volume pot with a stereo stepped attenuators 100K that I have in hand.How did the other BYOB amp owner replace the stock PS caps with BG 10,000mF/63V? Do you have any pics or do you know what caps have to be replaced (I can see the two silver caps and two small caps in between)?Tan
But I do not use it anymore...if you wait long enough the Byob amp starts to "shine" without using the BG.I left the BG in for the DAC as a kind of power buffer...anyway I made some extra psu cables so I can switch and play with or without BG.
http://picasaweb.google.com/home
QuoteBut I do not use it anymore...if you wait long enough the Byob amp starts to "shine" without using the BG.I left the BG in for the DAC as a kind of power buffer...anyway I made some extra psu cables so I can switch and play with or without BG.Tony,I got the BYOB amp from an audiogoner so I guess I had been used for around 6 months. The BYOB amp in my system sounds too loud with less volume. That is why I am thinking to modify it with a stepped attenuator, would that be a good idea? Besides I did replace the stock coupling caps with Sonicap 10mF/200v and bypassed with Vit Q 0.1mF/600v. However, there is less congested sound (with stock Wima caps) but the loudness is still there. :scratch:FYI the BYOB amp is driving my horn-based speakers (97dB). Thanks.Regards,Tan
