0 Members and 1 Guest are viewing this topic. Read 9522 times.
My main concern is in the area of driver excursion, I aim to cross it at no less than 300 hz, I may cross at 400 initially for hopefully a bit of safety and see if I can hear any stress, then lower it towards 300 if I can.
wow, those two graphs look different. I've had the fixed idea for a while now that for OB the wider the baffle the better, I suppose that is a carry over from trying to maximize bass extension.
... so I have downloaded the edge and am in the process of nutting it out-by the scientific method of clicking buttons and seeing what happens, ie no knowledge at all!! ha ha.
My main problem of course is using a large woofer, it is easier and more aesthetically pleasing to keep the large baffle all the way, and be totally lazy and rely on the deqx to make it all work OK. But like everything, the less correction needed the better I would expect.
So will muck about with various shapes and see what the response looks like. In a general sense, do the real world results come close to the results predicted by the Edge?
So the quick question, if someone has experience with it, how far from the baffle should i do the measurements and then correction?? With the sealed setup, I normally measure from a meter, not sure if that is sufficient distance for a dipole.
Very soon I will be building a pair of subs, using four peerless xls 10's a side, but arranged vertically (when that height box is placed next to the simulated wide baffle, ie 'extending' the width and the mid is now asymmetrical in the extended baffle really helps knock out the huge dip in the simulations) which I could run up to say 80 hz. The reason I mention this is that MAY allow me to run the (now) upper bass unit open baffle as well, as I'm idly wondering whether the transition from sealed bass to OB midrange (given the x-over occurs at 300-320 hz) may be discontinuous sonically at those frequencies.
