0 Members and 1 Guest are viewing this topic. Read 8029 times.
Any progress?
Kevin... I presume the 4-channel UcD180HG will drive a pair of 2-way loudspeakers... is that correct? Or, are you referring to the 2.5 way tower? Still, that's a lot of power for a rather small speaker (especially the tweeter).I don't think cost is as big of a factor if this is for a dedicated two channel rig. Most high end systems have separates, and couple that with the amount of control, I think this will sell well. Could you do a WWMT with a 1x400 driving the Ws and 2x180 driving the MT? This would also be a 2.5-way active loudspeaker. You could also do a midlevel version that is 2x180 (180 for the WW and 180 for the MT). That would be interesting to say the least .
"The active version will use our Exodus Amplifier as a basis for the electronics. It will probably be a 4-channel UcD180HG build with the active crossover built into the Hypex based amplifier chassis. Control over the EQ section will be via a USB cable and you will need a computer to interface with it for room measurements, & PEQ settings. "Kevin, this sounds quite exciting. Will you be suggesting / selling some solution that integrates the Kepler with some of your new subwoofers? I'm thinking this - sealed active Kepler, sealed eq'd 12" or 15" sub. How do you recommend best integrating the two for music listening (and some HT use)?
So when do you think you'll be wanting guinnea pigs to test out the active systems and their tweaking capabilities in nice challenging 11'x20' theater rooms with 8' wide screens requiring tighter than optimal to wall placement of speakers?
#5. Dipole design with a pair of EX-6.5s, BG NEO3 & a pair of our new DPL-10s.
