Is there such thing as a phase inverter?
0 Members and 1 Guest are viewing this topic. Read 1724 times.
Hantra
« on: 8 Jan 2003, 01:36 pm »
All:
While a review of the Nixon DAC will be forthcoming as soon as I can shoot it out with something, I am in need of something to invert phase.  Scott's DAC is phase inverting, and I don't have a problem with that.  My only other source is an XM receiver, and I am wondering if there is something that will invert phase at the line level so that I can use it with XM.
I wouldn't want anything else in my CD signal path, but XM doesn't sound as good as CD, so it won't hurt my feelings to use something there.
Any ideas?
Thx!
B
Wayne1
« Reply #1 on: 8 Jan 2003, 03:04 pm »
B,
All you need to do is to wire your interconnects from the XM out of phase.
Take the ground wire from the XM output and connect it to the + input on your integrated.
I can build you a set of M-80s wired that way if you wish :D
nathanm
« Reply #2 on: 8 Jan 2003, 08:47 pm »
:idea: Why not design a cable with a miniature toggle switch built into one of the connectors?
