B60R lid - how to remove
0 Members and 1 Guest are viewing this topic. Read 1467 times.
julian
« on: 23 Jun 2007, 10:34 am »
Hi - I need to get the lid off my B60R SST so I can get at the remote dip switches. There's a whole bunch of screws in the case, some cross-head, some a square drive and even an ordinary slot-head on the back right corner! Which ones do I take out?
Burke
Re: B60R lid - how to remove
« Reply #1 on: 23 Jun 2007, 10:04 pm »
The ones that hold it on, of course. :>)
The manual doesn't show anything about use of the internal DIP switches, so you are already in fairly advanced territory knowing about what they do... perhaps your source of information about the internal DIP switches could give some insight into how to access them? (IOW, maybe they would know which screws are the ones to take out so you can remove the cover to let you get at the switches.)
Also I'm not sure but what doing something with the internal DIP switches might have an effect on the warranty, since they are inside the case, which doesn't sound like it was designed for easy end user access. Warranty in the manual states: "Tampering by persons other than factory authorized service personnel or failure to fully comply with Bryston operating instructions voids the warranty." Might be worth clarifying with Bryston before you take off the lid.
Good luck,
Burke
julian
« Reply #2 on: 23 Jun 2007, 11:10 pm »
Burke, you are correct, my source could probably tell me which screws to remove. Unfortunately he neglected so to do and is probably unavailable 'till Monday. So I thought I might try to save a little time.
