Balance out of a DAC to none balance in of AKSA.
0 Members and 1 Guest are viewing this topic. Read 1995 times.
SamL
« on: 23 Jun 2007, 09:42 am »
Just wonder if I can connect the pin 1 (ground) and pin 2 (hot) of a balance out to a 50K Apls port and from there to the none balance in of AKSA?
I read that balance out is 6db more than line out, do I get 6db gain by doing so?
I found some discussion about how to mod AKSA to take balance in but try not to mod my AKSA if I can avoid.
Edit: Ops! Found a major flow in my question.  :duh: Retype :)
« Last Edit: 23 Jun 2007, 10:12 am by SamL »
AKSA
Re: Balance out of a DAC to none balance in of AKSA.
« Reply #1 on: 23 Jun 2007, 10:48 am »
Yes, Sam,
this should work fine.  Take one of the hot outputs, connect to the AKSA, and the center, ground termination to signal ground, and then pass a 33K resistor from the other hot output to ground.
The AKSA will then function in single ended input mode;  the usual way, and the balanced line from the preamp should be close to evenly loaded.
Gain will drop by 6dB to the same levels as a single ended output from a regular preamp.
Hugh
SamL
« Reply #2 on: 24 Jun 2007, 08:52 am »
Good to know that this is do-able.  :green:
Wonder if I can expend the idea by connecting the pin 2 (hot) to AKSA100, pin3 (hot) to AKSA55 and pin 1 (ground) to both AKSA100/55 ground in. One problem about this is the inverted polarity between pin2 (hot) and 3 (hot but inverted polarity). Is there an easy way to reinvent the polarity of pin3 back to that of pin2? Will be excellent if this can be done.  :drool:
AKSA
« Reply #3 on: 24 Jun 2007, 11:36 am »
Sam,
Only with a transformer or phase inverting chip.......
Not worth it.
Hugh
