Does anybody have experience with Genalex Gold Lion KT-88 reissues?
0 Members and 1 Guest are viewing this topic. Read 5422 times.
zybar
If you have tried them, please let me know the following:
What are you using them in?
What do they sound like?
What did they replace?
George
Beatlebum
Hey George,
I have the GL reissues in my Music Reference RM-200 (which I am selling BTW). They replaced the Shuguang KT88's. While the Shuggie's are a very good tube, the GL's bettered them in every way. Better , more extended and delicate highs, even more midrange magic and especially in the bass dept. Deep, rich bass. Definately a worthwhile upgrade IMHO. I bought mine from Jim McShane (no affiliation).
zybar
Hey George,
I was just checking his site and thinking of trying them with my Bella Extreme 100's (they would replace Valve Art KT-88's).
Thanks for your reply.
George
toobluvr
George...
FWIW, in my ASL AQ1001 DT I replaced the stock Valve Art KT88 with Shuguang KT88sc solid plates.  I thought the improvement was worthwhile.  If I'm not mistaken, I believe that Bill at Response likes these tubes as well.
If you check the Penta Labs website, they sell the identical tubes, but I got mine from a cheaper source.
Check this link for an informative thread on them:
http://forum.audiogon.com/cgi-bin/fr.pl?htech&1137889853&openusid&zzSpelly&4&5#Spelly
No experience with the Gold Lion reissues...I don't believe they were available when I had the kt-88 amp.
PS:  I have also dealt with Jim McShane.  He is a good guy and his prices are reasonable.
zybar
George...
Thanks John.
George
TONEPUB
These are the ones that are about 400 bucks each and you get them from Western Electric?
Or am I confused?
thanks!
zybar
Or am I confused?
thanks!
These are actually re-issues done by New Sensor Corp. out of Russia.
Here is some info on the tubes:
http://www.musicdirect.com/products/detail.asp?sku=AGNLXGLKT88
The re-issue tubes go for about $100/pair.  Not cheap, but certainly well under the costs of NOS Genalex Gold Lions.
George
EthanH
I'm running the GL reissues in a Cayin TA-30 amplifier.  I can't compare these to any other KT88s, but I've previously used the Cayin with various EL34 power tubes (Cryo'd ValveArts, EH 6CA7, New Sensor Svetlanas).
I really like the New Sensor Gold Lions.  IMO, they have a very natural, slightly warm midrange and excellent bass.  They have a much bigger sound than any EL34 I've tried, and the high frequencies are smooth but extended.  In my system the two qualities I notice most with these tubes is an excellent sense of space and a very robust and defined low end.
I have a modest system and limited experience with tubes, but that's the short of what I'm hearing.  Hope it helps a bit. :wave:
zybar
I hope the KT-88's provide exactly what you describe.
George
Joey B
There has been a lot of debate on these tubes at tube asylum . Mcshane is really high on them . :D
Joe
zybar
The tubes have arrived (thanks to Jim McShane) and I will be trying them out tomorrow.
George
« Last Edit: 25 Jul 2007, 04:32 am by zybar »
ZLS
I was also turned on to KT 88's by Jin McShane.  What I can say is that I prefer them to the sound of  Cyro'ed EH KT90's.  Running a rebuilt Harmon Kardon Citation II.
carusoracer
George
Nice to see a affordable authorized re issue...Please share your findings :thumb:
EthanH
They needed about 60 hours to start sounding their best in my system.  At first the treble was a bit disconnected sounding, but after about a week that went away and I've been really enjoying them since.  Hope you like 'em.
zybar
So, zybar, what do you think?
I recently installed some cryo'd Valve Art KT88 in the Leben CS600, and they are very nice and liquid. Extended highs without etch. Bass is very deep...almost too deep with the Sonata III, though. Wondering how the Gold Lion re-issues stack up in your application.
Thinking I might have to go to EL34 to tone down the bass some.
Tvad,
If you are looking to tone down the bass, you should look elsewhere.   aa
The new Gold Lion re-issues are indeed an improvement over the Valve Art KT-88's I was using.
There is more texture and air with the GL's.  By comparison, the VA's sound a little flat and compressed.
Voices are more palpable and real sounding.  I especially like the added seductiveness and weight.   :thumb:
There is also better attack and decay with the GL's.  I really like the way the first strike of a drum or bongo...it sounds fast, tight, and impactful.
Soundstage is slightly bigger with the GL's as well.
These are just my initial impressions using a few of my normal test tracks:
Rusted Root - When I Woke: Drump Trip, Cat Turned Blue, Laugh As the Sun
Natalie Merchant - Tigerlily: Carnival, The Letter, Cowboy Romance
Harry Connick Jr. - She:  She, Trouble, The Party, Booker
Ben Harper - Fight For Your Life: Gold to Me, Burn One Down, God fearing Man
George
zybar
Hmm...everything you describe I'm getting with the Valve Art KT88. Too bad tubes can't be auditioned. It gets silly expensive spending hundreds on tubes just to hear them in a system.
IMO.
I have a hunch the Sonata III are going to change substantially during the next 450 hours. Perhaps the bass will not be an issue at the end of the break-in process.
I agree that the Valve Art are quite good.
I just think the GL's do everything a little better.
Whether that is worth the extra cash is hard to say.
George
macrojack
Good idea you have there for a tube lending library. And you're just the guy to start it. You've done the research, you have the connections, you have inventory, and it was your idea.
Maybe you've been planning such a thing for a while and that's why you are encouraging me to get into tubes. Is Zybar going to run the East Coast Office?
macrojack
Nice to know you can be dumb. If I were smart, I'd keep that in mind.
What prevents somebody from borrowing a strong tube and returning a weak one?
macrojack
So, getting away with it would require dumb luck?
jrebman
I'll have a new amp in about 2 weeks that comes with the GL KT-88s and a local friend has a new matched quad of Sophias (which appear to be hand-picked Shuguangs), so one of these days I'll be able to compare these two brands.
George, you don't happen to have a pair of Bendix 6900s lying around taking up space and looking for a new home, do you? :D
-- Jim
