USB Off-Ramp Turbo2 - 2 channel music and AC3/DTS questions...
0 Members and 1 Guest are viewing this topic. Read 1956 times.
mat3o
Hi,
I'm thinking of buying a USB off-ramp turbo 2 or maybe a USB Freeway 2 and I have a couple of questions.
1) Can I use the "driverless" firmware with Foobar to play music and the M-Audio driver with Zoom player/ffdshow for movies (AC3/DTS)?. If I understand it well the new driverless firmware is better than the m-audio. I listen 50% music and 50% movies. Maybe a bit more to music than movies, and I think that would be great to use the driverless for 2 channel music.
2) Would the Off-Ramp and/or Freeway improve the sound quality of movies comparing it with a standar m-audio transit or audiophile connected to a pre/pro?. I'm planning to connect it directly to a Meridian 568.2mm. I think this question is a bit noobie, but I can't find any comments about the sound quality with DVD sources or a comparative with other products.
Thanks very much :)
« Last Edit: 22 Jun 2007, 05:26 pm by mat3o »
audioengr
Hi,
Thanks very much :)
1) no, you would have to use the m-audio driver to do AC3, not the new firmware
2) Yes, definitely.  Much better than a Transit or Audiophile USB.
Steve N.
mat3o
Hi Steve,
Thanks for the quick reply  :D
Ok, I understand that I need to use the m-audio driver to do AC3, but in that case will I need to use also the m-audio driver with foobar to listen to stereo music?. Or is it possible to have installed the m-audio driver for ac3 duties and to use the new driverless firmware with foobar?. hmm, maybe I'm messing things here but supposedly that way I will be able to do ac3/dts when I want to watch a movie, but I don't need to compromise audio quality when listen to stereo music.
Does that makes sense?, Or I shouldn't worry about that?
Thanks again.
audioengr
Hi Steve,
Thanks again.
You have to use one or the other.  The firmware is hardware soldered-in.
Steve N.
