0 Members and 1 Guest are viewing this topic. Read 4042 times.
I would consider an NHT X2 crossover: http://nhthifi.com/2006/products/s/x2.htmlRun the left and right preamp outs into the X2 (set to sum into a mono sub output), run the left and right high-pass outputs to your amp(s) and the sub output to your sub.
Guys,The only place I can see to find the NHT X2 xo is from audioadvisor. I might have to call a local Anderson's to see if I can get it. I want to be able to get this to work this weekend.thanks,Coolsat
Glad to hear you have a configuration that works OK. What would be the advantage of using the spare L/R outputs versus the main L/R outputs of the AVP?
