0 Members and 1 Guest are viewing this topic. Read 7862 times.
2. With the vertical line the speakers cannot differentiate sound vertically, so I don't know how a such a speaker could image vertically.
In my experience OB provides more of a "wall of sound" and less pin-point imaging that audiophile main stream goes for. This more detailed imaging is more accurate and allows for greater levels of detail as I've found switching amps which has resulted in smaller, better defined, and more detailed sound from a given instrument (like taking glasses on and off a nearsighted person). OTOH the recording industry has gone "over the top" with hyper detail, IME. I may not care to know what the singer had for breakfast or to sit on their lap during the performance. OB helps the brain "relax" from trying to analyze precise imaging and detail so that it can concentrate on the emotive aspects of the music.
Hi Daygloworange,You are right about the low distortion of the line array. The cones are hardly moving most of the time. This is bound to reduce cone breakup and resonance nodes considerably for a given SPL and you can hear the improvement over the single drive unit version instantly. Really there is just no comparison.
If cheers means you are going for a drink, I’ll join you.RegardsPaul
I have also played a vintage Fender Stratocaster through a marshall stack (two cabs) when I played in bands as a teenager. The line source can reproduce this without wilting.
