Translucent Audio Reference Line Cables
0 Members and 1 Guest are viewing this topic. Read 1454 times.
Translucent Audio
  • Gold Reference Audio Cables
    • Translucent Audio Cables
« on: 21 Jun 2007, 03:24 pm »
Translucent Audio Reference Line cables are designed for audiophiles who are passionate about music. Our cables offer superb resolution in the areas of transparency, focus, imaging, and the frequency extremes. Acoustic instruments and voices sound natural and smooth with a vibrancy and truthfulness of timbre. This articulation renders an exciting musical experience.
Translucent Audio cables utilize OCC silver-copper alloy (unplated) conductors. Professor A. Ohno of the Chiba Institute of Technology developed the Ohno Continuous Casting process to achieve conductors of unidirectional structure, impurity-free, non-crystal boundaries, and low electrical resistance. The combination of these metals results in smooth, detailed sonic qualities compared to singular metals. Our double helix conductor geometry maintains uniform electrical characteristics along the cable span.
Cable materials are custom manufactured and hand terminated to the highest standards. Dielectric spiral strands support the wire structure in a tightly enclosed core to eliminate resonance and isolation bearings decouple the connectors from the cable (interconnects). Our cables do not use layers of cosmetic materials and fillers that can adversely alter the transmission properties of the cable.
Precision manufactured Xhadow audiophile grade RCA or XLR connectors terminate our interconnect and digital cables. Lathed RCA bodies of oxygen-free pure copper are clad in silver. Machined Teflon insulator blocks feature silver spring contacts and tooled pins. Turned outer covers from aluminum rod-stock are anodized for a durable non-conductive finish. Solderless wire terminations create a seamless, uncontaminated bond to the connector contacts. The positive fitting plugs ensure low contact resistance for perfect signal continuity.
Quality WBT solderless spades or banana plugs terminate our speaker cables. The compression spades maintain a constant pressure at the binding post. Machined locking banana plugs made from OFC copper are 24-carat gold plated.
Our cables are the perfect match for all solid-state and vacuum tube components revealing the best your system has to offer. We invite you to audition our cables in your system for 30-days and discover the sonic virtues and build quality of our products. Buy direct from the manufacturer and save over 50% off list prices.
http://www.translucentaudio.com
« Last Edit: 8 Jul 2007, 01:05 am by Translucent Audio »
