Poll
no sound from my Khartago
0 (0%)
2
0 (0%)
Total Members Voted: 0
0 Members and 1 Guest are viewing this topic. Read 1498 times.
radhk
« on: 15 Jun 2007, 09:54 am »
Hi all,
Recently, I found that there was no sound from my khartago. When I power up the khartago, the LED at front lights up but I can't hear the usual "click" sound of the relay inside. I check the fuses inside and outside and they are good.
Can you suggest what I can check? I don't think I can ship it back for checking as I'm in Hong Kong. I appreciate if someone can help so that I can fix the problem locally. Thanks a lot.
Best regards,
Calvin
radhk
Re: no sound from my Khartago
« Reply #1 on: 15 Jun 2007, 04:37 pm »
I figured out that it was the problem of the on/off
switch. It was not completely closed (not zero
resistance) when I turned it on.
I think I can buy the on/off switch and change it tomorrow. Thanks.  :D
