U-frame, 260 Hz - 6 kHz?
0 Members and 1 Guest are viewing this topic. Read 2149 times.
James Romeyn
« on: 15 Jun 2007, 01:19 am »
System will employ two 8" tall x 4" wide planar dipoles in a vertical array, 260 Hz - 6 kHz.
Preference is to build a U-frame for the planars; rear radiation to be damped by a high-density foam pad to be adjusted in-out from the planar's rear surface depending on front wall spacing.
What are recommended dimensions for the U-frame housing the planars?  In case height matters, minimum is estimated 20".
« Last Edit: 15 Jun 2007, 02:49 pm by RibbonSpeakers.net »
ttan98
Re: U-frame, 260 Hz - 6 kHz?
« Reply #1 on: 15 Jun 2007, 01:41 am »
Use Martin King or John K software, visit their website.
Their s/w are quite cheap.
el`Ol
« Reply #2 on: 15 Jun 2007, 04:15 pm »
12" should be a sufficient baffle width, a u-frame won`t be necessary, unless you want to reduce the dipole character.
http://melhuish.org/audio/baffle.html
