Butler Audio 5150 - Hybrid Multichannel Amp
0 Members and 1 Guest are viewing this topic. Read 1926 times.
draco
« on: 14 Jun 2007, 07:37 pm »
You probably know about this unique product if you are reading this ad. Otherwise, full details can be found at www.butleraudio.com. Also, 3 very favorable reviews on web: Ultimate Audio, About.com and Home Theatre Magazine.
Approximately 200 watts x 5.
Purchased from authorized dealer in December 2004. Balance of 5-year warranty is transferable. Not much use (I constantly move equipment in and out) and has been boxed up the past 12 months. The unit is absolutely pristine - not a mark anywhere that I can see. Please PM me for photos if you are serious.
Retail is $3295. Asking $1850. Will split shipping and, if necessary, paypal.
JAMn Joe
    • http://www.jamnaudio.com
Re: Butler Audio 5150 - Hybrid Multichannel Amp
« Reply #1 on: 14 Jun 2007, 11:29 pm »
Here are the correct specifications direct from the Butler web-site.
Specifications:
•  Rated Power (all channels driven):
5 x 150 Watts RMS per channel @ 8 ohms
5 x 225 Watts RMS per channel @ 4 ohms
•  Freq response: 20Hz to 20kHz (+/- 0.5dB)
Power Bandwidth: -3dB, 50kHz
•  THD: <0.10% @ 8 Ohms, <0.15% @ 4 Ohms
•  S/N Ratio: Better than 110dB (A-Wtd)
•  Slew Rate: 15v/µsec
•  Input Sensitivity: 1.5V for 150 Watts into 8 Ohms
•  Input Impedance: 47k Ohms
•  Idling Consumption: Approx. 120 Watts
(Approx. 1A @ 120VAC or 0.5A @ 230VAC)
•  AC Consumption (Nominal power):
1200 Watts @ 8 Ohms - 10A (120VAC), 5A (230VAC)
1800 Watts @ 4 Ohms - 15A (120VAC), 8A (230VAC)
•  Dimensions: 17"W x 16"D x 8.5"H w/feet (7"H w/o feet)
•  Weight: 48 Lbs. (19.2Kgs.)
Big Red Machine
« Reply #2 on: 15 Jun 2007, 01:43 pm »
I've always wanted to try a tube amp in my HT.  Has anyone else used one?
Must resist... :nono:
Rob Babcock
« Reply #3 on: 16 Jun 2007, 04:14 am »
I've used my Butler TDB-3150 in my HT.  Very nice indeed! aa
