Nagys Audio - State of the Art Audio Interconnect Cables SUPER DEAL!! $150 pr.
0 Members and 1 Guest are viewing this topic. Read 5844 times.
NagysAudio
    • http://www.nagysaudio.com
Hi again, all military or aerospace solder has lead in it. Lead free solder is junk (at the moment anyways), it cannot stand to harsh environment and the connection will fail in time. Just search the web for military specd solder. You'll find many suppliers, however getting them to sell you any is another story.
Nick B
I'd be interested in a tour soon. Just bought some new cables and would be interesting to hear the differences (if any) with your product
Nick.
guest1632
  • Guest
Hi, Well then the military had better invent something new, because the whole manufacturing world is fast going away from lead bigtime. What are the "harsh" conditions? I have a friend in the audio industry, well known. He has recently gone to the lead free solder. He recently make up a pair of Interconnects for himself. He told me there was a glare using the old Lead solder. With the new stuff, it is gone. I recently purchased a Soldering station from a company here in AZ. On the soldering side, they do have some Lead-free solder manufactured to milspec.
Ray
guest1632
  • Guest
Nick.
Hi Nick,
What cables did you buy? I too am n the search for cables.
Ray
Nick B
Hi Nick,
Ray
[/quote]
Hi Ray
I bought a pair of Grover's at AN. The group buy expires tonight. 30% discount was very nice.
Nick
guest1632
  • Guest
Hi Nick,
Ray
Hi Nick,
Wow! Yeah, this would be a good comparison. So I understand, Grover's cables aren't conventional. Enough said, don't wish to do any hijacking of this thread. The best to you.
Ray
Hi Ray
Nick
[/quote]
NagysAudio
Yes, they do have some lead free mil spec solder available. Military/Defense/Aerospace industries are beginning to transition very slowly, but it's proving to be very difficult. In real harsh environments, Sea/Cold/Weather etc. lead free is total garbage. But even under normal conditions, the connection deteriorates and fails much quicker. This is mostly due to tin imperfections in the joint which grow with time. There's no good solution yet, but that's not to say that there won't be soon.
Regarding the glare. Lead will not give you a glaring sound. Glare can be due to poor soldering skills (like cold solder joint where you have impedance problems), or just plain low quality solder. For electronics, good solder should melt at not too high of a temperature and flow beautifully. When set, it should have a shinny joint. Soldering paste should ALWAYS be applied to the metal surfaces. Rosin core solder is not a substitute for this.
guest1632
  • Guest
Interesting. So what happens, does it go to a cold solder joint?
Ray
NagysAudio
The joint will fail electrically, short circuit, etc
