0 Members and 1 Guest are viewing this topic. Read 2340 times.
With all due respect, I would not cover the absorbtion in a multi-channel room like that. Target decay times are lower in a multi-channel environment. If you want to reduce the HF absorbtion in the rear absorbers, use something like a 10-20 mil plastic stretched tight or just use an FSK facing.Corners are great for broadband but the front wall also needs to be dead to keep the rear surround channels from reflecting off the front wall and messing up the front soundstage. This is very different than in a 2 channel room.Bryan
