Question about selecting/purchasing vinyl
0 Members and 1 Guest are viewing this topic. Read 1297 times.
jcrane
« on: 5 Jun 2007, 02:04 pm »
Ok, I am on the vinyl bandwagon again. Started thinking of making the leap but wanted to know how to get educated about the different types of vinyls out there.
Looked at a couple sites and they had 120gram, 140gram, 150gram, 180gram, 200gram, just plain old vinyl and about a billion others.
What should one look for if they are interested in (at least for the moment) only new stuff. Is heavier better? Are certain brands better? Help me before I lose interest again :scratch:
Jamie
TheChairGuy
Re: Question about selecting/purchasing vinyl
« Reply #1 on: 5 Jun 2007, 02:43 pm »
Yes, certain brands seem to be better than others.  It's probably more the formulation than actual thickness that causes good or badly manufactured albums.
The audiophool pressings are usually 180 or 200 gram - you pay for it, but they generally sound quieter. The deeper grooves wear less over time and they are cut more prudently - likely with lesser speeds of the cutting lathe that carves them out.
Don't get all hung up about vinyl quality - go get a vacuum record cleaner and LAST Record Preservative and take your shots like the rest of us.  It's hit or miss as new albums are scarce and pricey at $30+.
I have found that the pressings before about 1965, which are uniformly thick, generally are made of some compound back then that was very noisy.  It was made  worse by conical and often heavy tracking forces of that day.  So, I avoid these (used) albums as they invariably are putrid sounding.  You might want to as well.
I'm sure there will be others chiming in, as well, on this subject - so don't let mine be the be-all and end-all word on this  :)
Welcome back, err, home to where music thrives - vinyl  :thumb:
ricmon
« Reply #2 on: 5 Jun 2007, 03:00 pm »
If you like jazz I have recently started listening to the 45 rpm disc from "Analogue Productions Jazz Fantasy" reissues.  These platters are pretty amazing in terms of sound.
http://www.analogueproductions.com/jazz/index.cfm.
Also I've found that after going a little further upstream in cartridge design all of my albums sound even more amazing.  So do as Chairguy says and just jump in, buy what ever get's the toes tapping (old or new heavy or not so heavy).
Scott F.
« Reply #3 on: 5 Jun 2007, 10:33 pm »
Hey Jamie,
If you get a chance, give me a buzz. I can walk you through some of the ins and outs. I'm usually home evenings after 6 or so (not sure what your work schedule is these days).
Hey, are you going to be able to make the GAS Recording session on the 14th?
Oh, remind me, I'd got your box for the CAL DAC sitting here. Maybe we can stir up a round of golf. Mike D and Ron have been talking about it for a while.
Wayner
« Reply #4 on: 6 Jun 2007, 12:47 am »
I've bought many used albums that are near perfect because someone didn't like the band. In summation, they've never played the record. I have bought many albums "used" for $3 that are "mint". Go to local antique shops and be selective, that's my advice.
Fwiw.
W
