0 Members and 1 Guest are viewing this topic. Read 4275 times.
Jim, What are the dimensions on those speakers?
How do you mount those?
Do these have to be at the sides of the audience, or would they work well even slightly behind the audience?
What is the cost relative to the HT1s?
Would these be recommended in lieu of the bi/dipoles?
Those are really cool looking. Is there a SongSurround version of that with the slanted baffle?
Nuance - Quote from: Nuance on 1 Jan 2009, 04:01 pmThose are really cool looking. Is there a SongSurround version of that with the slanted baffle?Currently there is not. A slanted cabinet is more difficult and labor intensive to build. So I am not sure if it would be cost justified or not (it would probably add about $200 to the cost of a pair). But this is a decision for the marketplace to make. If people want them, we will certainly build them.- Jim
Thank you. When I order the SongSurround's they'll likely be mounted on the wall. I will probably go with a top ported design, though (those were top ported SongSurrounds and not HT1's, right?).
Quote from: Nuance on 1 Jan 2009, 09:29 pmThank you. When I order the SongSurround's they'll likely be mounted on the wall. I will probably go with a top ported design, though (those were top ported SongSurrounds and not HT1's, right?). I don't know which you are referring to, but we have done top ported SongSurrounds as well. By the way, we should be finishing up an LCY version of the SongCenter in the next week or so. I'll post details when complete.- Jim
