Need info for actual size of spade plug needed for ACI Jaguars
0 Members and 1 Guest are viewing this topic. Read 1406 times.
Lkdog
As noted above-need to know what size of spades I need for the speaker posts for the ACI Jaguars (most recent edition which ended in summer 2005).
I use bi-wire with DH Labs Q10 wire which is 10 ga which will need the spades on bottom posts.
On top I use DH Labs T14 with banana plugs.
Thanks.
Mike Dzurko
You'll need either the SP10 or the SP2W spades found on this page:
http://www.audioc.com/accessories1/dhlabs/q10.htm
Lkdog
Thanks Mike.
