U-baffle directivity
0 Members and 1 Guest are viewing this topic. Read 2983 times.
Polarbear
« on: 1 Jun 2007, 10:39 pm »
I know the dipole woofer are quite directive in the bass area. Is it the same rule for U-baffle? Would it beneficial to point the U-baffle at the listener?
Cheers
Bjørn
opnly bafld
Re: U-baffle directivity
« Reply #1 on: 2 Jun 2007, 01:51 am »
Polarbear
« Reply #2 on: 2 Jun 2007, 09:07 am »
Thanks Lin
I have read these pages, but I 'm still confused.
From what I can see out of these charts (at left), the respons of the H-baffle is least on axis. And the U-baffle is at it's peak at +45 deg. Am I missing something?
cheers
Bjørn
Rudolf
« Reply #3 on: 2 Jun 2007, 01:14 pm »
Bjørn,
top of the diagram is on axis front, bottom of the diagram is on axis rear.
So +/- 45° from axis would be almost the same SPL for a U-frame. Not much directivity in that range. It is the difference between front and rear radiation you want in an U-frame.
Polarbear
« Reply #4 on: 2 Jun 2007, 01:48 pm »
Bjørn,
Ahaa. Thanks Rudolf. That makes more sense.
So it's not much use to point the U-baffle at the listener for SPL purpose. Could be useful to control room-modes though?
bj
Rudolf
« Reply #5 on: 3 Jun 2007, 07:50 pm »
bj,
in the first place a U-frame will be useful to have better control over the rear bass output. If you can´t place your OB or H-frame far enough from the front wall, a U-frame should be helpful. As shown in the diagram, regarding radiation to the front a U-frame of certain depth is 6 dB more efficient than a H-frame of the same size.
Because the U-frame has less directivity than a dipole, in theory the U frame should excite more room modes than a dipole. But if a U-frame gives you more freedom of placement in the room, this could easily be more helpful to control room modes than the radiation pattern.
