Is it normal that I hear a plop in my speakers when I turn my 4B-SST off?
0 Members and 1 Guest are viewing this topic. Read 3364 times.
Hoiman
I always thought that a plop sound when you turn your amplifier on/off is not good for your speakers?
rabpaul
I turn off my preamp first and only then power down the amp. I do hear a tiny pip from the speakers which is quite different from your plop which I presume is loud?
Hoiman
No it isn't that loud but still present. And I also always turn the pre-apm off first.
« Last Edit: 31 May 2007, 10:14 am by Hoiman »
nuhi
Only a tick here, so I would say a plop isn't normal without putting much significance to it when you said it's not loud. Maybe it depends on the speakers.
Why would you first turn off the devices upstream, that can only cause more glitches.
And one dealer (he doesn't sell Bryston) told me that it's better when it ticks (or plops), that means that the signal path is not crowded with the relays or something like that.
Hoiman
SO it is normal. It's hard to explain a sound in another language, but a tick is the same for me as a plop.
  • The Demo is Everything!
    • http://www.bryston.com
The pop is just the power supply powering down - it is normal and will not cause any problems. It does vary from system to system depending on grounding and speaker efficiency etc.
james
Angelo62
Hi James,
did you get my two e-mails?
Sonny
Rabpaul...
it's not recommended that the preamp is turned off first...the order is that you turn the amps off, then the preamp and when you turn things on, the preamp is first, then the amps.
T
Hi James,
Hi Angelo,
No sorry I did not.
james
Angelo62
I've just sent it again.
mcullinan
 :wink: Is the plop coming from the speakers or you? Ha heh.. hmm..
M
Got it - sent the pictures.
james
Phoenix
My B60 pops like hell when I turn it off.
First the right, then the left channel.
However, my speakers have 98dB/W/m so I guess it's normal.
Never had problems because of that pop!
rabpaul
Does anyone know why you should power up (source>pre>amp) and power down (amp>pre>source)?
Hi,
It is just a precaution so that your speakers do not receive any turn-on or turn-off artifacts from the components in front of the power amp that may cause damage to your speaker drivers or crossover.
james
