FS Decware se84c-ex custom $450 obo...NEW REDUCED PRICE
0 Members and 1 Guest are viewing this topic. Read 1760 times.
dalza
NEW REDUCED PRICE $450obo
This is a factory customized se84c with the "ex" modification which makes it a perfect match for single-source 8ohm speakers.
The amplifier, serial# 584, was built in July 2004.  I am the original, and only, owner of this amplifier and can assure you that it was handled with great care and is in excellent condition. There are no blemishes that I can see.
The amplifier was recently sent to Decware for an inspection and had its output transformer replaced, so it is essentially like new. N.B.  Although the label on the bottom of the amp states that it is set for World Voltage(240volts), at the time of the transformer replacement it was reset by Decware to run at standard US voltage.
The two customizations to the amplifier are as follows:
1) Black case - the standard case for the non-select Decware models is gray.
2) Volume control on face plate - this mod allows you to set the volume without having to reach around to the back of the amplifier to do so...very convenient.
Images:
I am also including a complement of tubes, some NOS, which enhance even further the se84c's abilities.  Tubes included with the amplifier are:
Rectifier Tubes
1 - Used JAN Cetron "Potato Masher" 5R4WGB about 300hours of use
1 - Used RCA 5Y3GT..........................about 300hours of use
1 - Used Jan Philips 5Y3WGTA.............about 300hours of use
Output Tubes
2 - Used JJ Electronic EL84..................about 300hours of use
3 - Used Svetlana SV83......................about 300hours of use
Input Tubes
1 - New Sovtek 6N1P
1 - Used Sovtek 6N1P.........................about 300hours of use
1 - Used Jan Philips 6922.....................about 300hours of use
Images:
As most of you who are reading this ad already know, this is an extremely well balanced and rich sounding amplifier.  I am changing direction with my audio interests so this amplifier has to find a new home.
If you want to see the images above in larger format, please follow this link:
http://picasaweb.google.com/alzapied/Se84cExLARGE
If you have any questions please don't hesitate to ask.
Paypal Only.
Shipping is $20 anywhere in the lower 48 viaUPS.
U.S. Sales only.
« Last Edit: 11 Jul 2007, 12:32 pm by dalza »
dalza
Re: FS Decware se84c-ex custom $550 obo...REDUCED PRICE
« Reply #1 on: 23 Jun 2007, 07:18 pm »
Bump.  Reduced price.  $500 obo.
dalza
Re: FS Decware se84c-ex custom $450 obo...NEW REDUCED PRICE
« Reply #2 on: 11 Jul 2007, 12:33 pm »
BUMP!
New Price.  $450obo.
