0 Members and 1 Guest are viewing this topic. Read 9497 times.
Excellent news. I've already started working on the wife to order five of 'em.How difficult would it be to install the HxR12 in a UcD400 HG for those of us who are solder impaired?
It certainly doesn't look difficult. Hypex has designed the PCB for it to drop right in place. Of course.... it depends on how "solder impaired" you actually are. I imagine that it will involve cutting off the original TO-220 package voltage regulator also.
Quote from: Kevin Haskins on 25 May 2007, 10:03 pmIt certainly doesn't look difficult. Hypex has designed the PCB for it to drop right in place. Of course.... it depends on how "solder impaired" you actually are. I imagine that it will involve cutting off the original TO-220 package voltage regulator also. Let me put it this way, I'm older than dirt and I have the eye - hand coordination of a chicken with polio. The better question would have been, are you going to be offering the UCD400 HG modules with the HxR12s already installed?Also, has there been any word from Hypex as to when the new regulators will be available? A chicken with polio.... wouldn't that be chickenpox?
Yes...I'll be offering them installed. I've not been given an exact date but I believe we are talking 4-8 weeks.
Quote from: Kevin Haskins on 25 May 2007, 10:50 pmYes...I'll be offering them installed. I've not been given an exact date but I believe we are talking 4-8 weeks. Thanks. I'll start saving my pennies.Not to change the subject, but would the UCD400ADs that I have now work well to drive an IB (four Avalanche 18") in a four channel amp set-up?
How are you wiring the Avalanche? It depends on the impedance. If you get it anywhere between 2 -- 8 ohms you should be fine. IBs don't require much power. You can overdrive most drivers free-air with little power.
I've got the voltage regulators but waiting on the next order of UcD400HGs to arrive. That and some time to work on them & the web development. I have too many irons in the fire at the moment so I've not had a lot of time to work on the amps in general. Since the HGs have released most have sold by the time I get them. I have two installed in an amp but no HxR12s installed yet for listening test.
Kevin, can you clarify which components of the new UcD modules have been upgraded AND remain on the module after your modification process?It sounds like some of the upgraded module features aren't actually a benefit if a customer is having the full mods done because they get removed or replaced anyway. (This isn't a problem - I'm just trying to understand the changes with respect to the modded and unmodded configurations.)Thanks!
Oops - I misunderstood! Thanks for the clarification!
Quote from: brj on 20 Jul 2007, 05:30 pmOops - I misunderstood! Thanks for the clarification!No problem... I'm not a big proponent of modifying something that is already very well designed. I save voicing for the loudspeaker.
