0 Members and 1 Guest are viewing this topic. Read 17643 times.
ViggenWell figured out! That is absolutely correct. The other PSU outputs 5v to feed the SB3.Mine was a prototype! You might want to check prices with Paul Hynes at the link indicated above.
my attraction is arriving this weekend but i need to get ready.....
Hi GordonCongrats on your purchase of the Altmann Attraction DAC!The Altmann comes with a plastic connector plug with a screw each to secure the + and - bare ends of the cable from the PSU. Are you planning to use a Red Top Optima with the Altmann DAC?Best RegardsDennis
A few months back I ordered two separate shunt regulated linear power supplies to feed my SB3 and Altmann Attraction DAC. The units have finally arrived and are burning-in right now.
I am now starting to do this about the Altmann DAC , and Gordy sent me a PM strongly urging I study up on it. The only other one I am strongly considering other than it is the Promi DAC w tube Nick is doing but I am holding for him to do it with the C Core trannies. Not to mention there is no feed back on his DACs yet nobodies got 1.Rollo should be reporting on it in about 2 weeks he litterally went to Malassia.
1-Are any of you guys using the DAC w the Promi TVC, comments (I know 1 person had no luck there)? I know Dennis loves it with the TAP TVC.
3-Did you guys get the upgraded 48-192 k thing, do you like this? I use an SB so this I guess would have no use for a few more years? unless i feed it upsample.
4- Anybody got feed back on trying it with glass toslink?
6- Somebody had or still has the lessloss DAC, if you read this how did the Altmann stack up against it?
